Fuel Needle Issue
Fuel Needle Issue
The fuel needle in my wife's 98 Blazer is completely out of the normal E to F range and is pointing downwards. It has been sitting for a while and I noticed this when I had to jump it off to move it the other day. I'm trying to figure out what may be the cause of this. I hope my explanation is clear enough. I was going to try and draw what I'm talking about in paint, but I decided not to as it looks like something a baby drew. Thanks for any help/info that you guys can provide.
So anyhow... Second Gen Blazers have a notorious reputation of having an erratic fuel gauge. The gas gauge can fluctuate from full to empty and then anywhere in between when the sending unit that is incorporated with the fuel pump (located in the top of the fuel tank) starts to get worn.
I had the same issue with mine until I had a fuel pump failure and was forced to change the fuel pump. The gauge has worked well ever since. It's highly recommended throughout the BF site "members" that you should only use an ACDelco / Delphi fuel pump if you want any longevity out of the replacement pump and fuel gauge sending unit.
"but I decided not to as it looks like something a baby drew" lol, now that's funny.
As far as I know, if the sender is shorted to ground or open the needle would either point at Full or Empty all the time, never straight down. Sounds like the gauge itself has failed or there is voltage on the sender wire that should not be there.... as in two wires have shorted.
Pull the gauges fuse; any difference?
86sleeper
03-15-2013 06:09 PM
benzepeda
02-17-2009 02:05 PM
