fuel pressure
Old Aug 27, 2021 | 08:54 PM
GeorgeLG's Avatar
Another thought. Are you able to disconnect the fuel return line from the regulator while you have all of this apart to see if the fuel is passing through the regulator back to the tank when the pressure is dropping below 55 psi at the test port?
George
Old Aug 28, 2021 | 12:27 PM
papajim's Avatar
papajim is on a distinguished road
I will disconnect the fuel line from the regulator next and give that a try. Also when i pulled the injectors out the lug? the cylindrical end of the injector, stayed in the intake, now to pull the lower intake off to get them out. My guess is that i am going to have to get a new spider assembly, if so, maybe this will fix my problem, Is the injectors, Or, are the injectors fixable?
Old Aug 28, 2021 | 02:42 PM
GeorgeLG's Avatar
I don’t know about the ability to repair the injectors. You are not leaking back to the tank and you are not leaking externally or from the injectors. The only option left is the regulator Bleeding down below spec to the return line.
George
Old Sep 2, 2021 | 01:29 PM
papajim's Avatar
George
Ok, thanks George, I think I will just replace the spider assembly, this will hopefully fix the problem, the blazer has been driven very little over the past 4 years and no telling what is stuck open\closed,
Old Dec 4, 2021 | 11:29 AM
papajim's Avatar
I replaced the spider assembly and it fixed the problem. It now run like a champ again. Thanks for yyour help
Old Dec 4, 2021 | 11:56 AM
GeorgeLG's Avatar
Glad your fixed up, thanks for reporting back.
George
calee4nyaboy
Jul 15, 2018 01:10 PM
RSDEVIL
Oct 22, 2017 07:01 PM
oldmechanic
Aug 7, 2014 08:29 PM
youngone
Sep 11, 2010 04:22 PM
2FAST4U
Jan 6, 2006 08:21 AM
