fuel pressure regulator?
Old Mar 28, 2008 | 10:33 PM
firemansc32's Avatar
firemansc32 is an unknown quantity at this point
Default fuel pressure regulator?
What is the best way to test if the fpr is working properlyon a 2000 4.3L. I believe it is the reason my blazer has trouble starting.
[align=left] [/align]
Old Mar 28, 2008 | 11:23 PM
rriddle3's Avatar
Default RE: fuel pressure regulator?
Connect a fuel pressure gauge to the schraeder valve on the fuel inlet line above the engine, turn the ignition key to 'on' and the pressure should be ~51-62psi. Turn the key off and watch the gauge. The pressure should not drop more than ~2-3psi. If it does, you have a bad FPR. If the reading continues to drop over the next few minutes, you have a leak in the lines inside the upper manifold.
Old Mar 29, 2008 | 12:57 PM
Thanks rriddle3. I guess I get to start tearing apart the upper manifold now.
Terje
Nov 4, 2017 08:19 AM
vifa84
Jul 7, 2007 01:58 PM
jr9880
Feb 8, 2006 07:08 AM
jlinder
Aug 21, 2005 11:08 AM
