FUEL PRESSURE REGULATOR. where is it.
Old Jun 9, 2010 | 02:00 PM
laidblazer's Avatar
laidblazer is on a distinguished road
Default FUEL PRESSURE REGULATOR. where is it.
Can anyone exlain to me where the fuel pressure regulator is. thank you
Old Jun 9, 2010 | 02:41 PM
Dan 128's Avatar
Dan 128 is on a distinguished road
What year, make, and model do you have, then what size motor is in it. Lost without more info.
Old Jun 9, 2010 | 04:33 PM
laidblazer's Avatar
sorry bout that. i was in a hurry. its a 96 s10 blazer 2wd, with the 4.3.
Old Jun 9, 2010 | 05:17 PM
Dan 128's Avatar
You have either a (CMFI) or (CSEFI) injection system, commonly called spyder injection. The fuel pressure regulator is mounted on the fuel metering block which is housed just behind the throttle body. If you remove the air intake duct you'll be able to find it by following the fuel rail, it's the rectangled block that the full rail and the injector harness plug into covered mostly by the top plenum (The plastic part of the intake). You have to take the top plentum off in order to get the fuel metering block out. The regulator is mounted on the end of the fuel metering block. It uses the pressure inside the intake to control it (there are no vacum lines running to it like an external fuel pressure regulator).
If you plan on doing it yourself, slow down and pay close attention. The plastic fuel lines leading to the poppet valves will be brittle so handle with care or the fuel pressure valve won't be the only thing you have to replace.
A Haynes manual is a big help in a situation like this.
Terje
Nov 4, 2017 08:19 AM
vifa84
Jul 7, 2007 01:58 PM
jr9880
Feb 8, 2006 07:08 AM
jlinder
Aug 21, 2005 11:08 AM
