Fuel pump?
Old Dec 6, 2006 | 03:18 PM
recruiter's Avatar
recruiter is an unknown quantity at this point
Default Fuel pump?
My 1997 Blazer 4-door 4x4 is doing the following:
A conventional start won't start the engine - just turning the key causes it to turn over but not start.
To start the vehicle, the switch must be turned on until the warning lights pop on on the dash. They don't always come on, which makes me suspicious. Then when they do, a complete turn will start the engine.
My mechanic, in whom I'm losing trust by the minute, swears the fuel pump needs to be replaced. I, on the other hand, thought fuel pumps generally quit unannounced. Does the pump need replacement, and if so are there remanufactured alternatives to the gargatuan price - $700 - quoted me by the greedy local mechanic?
Old Dec 6, 2006 | 03:27 PM
hillbillyinOhio's Avatar
Default RE: Fuel pump?
i would t hink ignition switch, but I'm a rookie in diagnosing problems.
Old Dec 6, 2006 | 03:30 PM
jagblazer01's Avatar
yea i wouldnt think fuel pump....sounds like possibly an electrical problem. maybe starter or ignition
Old Dec 6, 2006 | 03:53 PM
recruiter's Avatar
that makes sense for this reason - there are times when a partial key turn in the ignition won't turn the dash warning lights on. you have to turn the key off and on to make that happen.
In the past, a fuel pump hasn't sent out failure warnings. It just quits. I was rather taken aback when the mechanic said, "oh, it's a fuel pump and that'll cost you about $700."
Old Dec 6, 2006 | 11:12 PM
Do you hear the fuel pump relay click on??? The relay is in the glove box behind the access panel.
Old Dec 6, 2006 | 11:24 PM
recruiter's Avatar
Heard a definite click after switching the ignition on.
Old Dec 6, 2006 | 11:41 PM
before I would go replacing the fuel pump, i would check the filter to make sure there is no clog, check voltage back there to make sure it is getting power, check fuses for fuel pump and fuel sending unit.
Old Dec 6, 2006 | 11:43 PM
recruiter's Avatar
Is the relay click a good thing or a bad thing?
Old Dec 6, 2006 | 11:52 PM
good, that usually means they are working.
Old Dec 7, 2006 | 12:27 AM
Chevy Lover's Avatar
I wouldn't even think of replacing the fuel pump before performing a fuel pump pressure test.
My concern is that your dash lights don't come on right away which make me wonder about the ignition switch.
Fuel pump pressure should be 55 to 60 psi when the key is turned to the "on" position.
