Fuel Pump Bad 2000 Blazer LS
Old Aug 15, 2011 | 08:41 AM
pcolaemt's Avatar
pcolaemt is on a distinguished road
Default Fuel Pump Bad 2000 Blazer LS
Truck stopped running while driving. Wouldnt stay cranked.checked fuel pressure it was 58 when turned key over & stylized @ 52. I couldnt hear the pump come on either. So I replaced fuel pump. Had to rewire the harness. Now pressure reads 62 with key on & 58-60 stabilized. truck runs fine now look at that little bit of pressure cause my truck not to stay running?
Old Aug 15, 2011 | 09:19 AM
pettyfog's Avatar
- I couldnt hear the pump come on either.
- Had to rewire the harness.
A mod to improve connection reliability
Shortest best 'bad FP' thread since I've been here.
Note your FP gauge is probably off calibration. The actual pressures were probably 3-4 points lower.
Points out, though that it doesnt take much degradation in fuel pressure performance to knock the system off.
Old Aug 15, 2011 | 04:02 PM
xgiovannix12's Avatar
I agree good to see the truck runs great now
Old Aug 15, 2011 | 06:22 PM
TouringMike's Avatar
TouringMike is on a distinguished road
I had a pump go on my '97 4 years back.
Pressure would be at ~58psi while running, up to 60psi under load (had the gauge up against the windscreen as I drove).
Anyway, at crank, pressure was 55, very hard starting. These things ('97 and up) need at a minimum, 60psi to fire. Amasing what 3 or 4 psi will do (or rather not do) Mine ended up being a small pin hole in the tube from the pump to the pump assembly top housing.
4 years later, still running great(Delphi pump)
Old Aug 15, 2011 | 07:06 PM
jswor19's Avatar
jswor19 is on a distinguished road
I can't figure out where to start a new thread so I'll post up here... My 01' Blazer LS 4.3L has 90K miles and just started kind of sputtering/ losing power while I'm driving. Almost like I'm running out of gas. Someone told me it was prob my fuel pump. I just fixed my a/c and changed oil/ oil pump right before the problem started if that may have something to do with it.. going on a road trip so I need to fix it ASAP. I was going to take it to the shop but I'm broke as a joke. Any suggestions? Or any Idea how much the shop would charge?
Old Aug 15, 2011 | 07:37 PM
pcolaemt's Avatar
To: jswor
For a 150 deposit, I would rent a fuel pressure gauge & check your pressure, if u cant hear the pump come on when you turn the key over chances are its the pump, but I would check pressure & fuel pump relay b4 spending 300$ on a pump. Took me 3hrs to do, and im not a mechanic. Probably cost double to have a shop do it
BouncingRadical
14
Nov 27, 2015 12:30 AM
aerovette99
46
Sep 28, 2015 10:04 AM
spittybays
Nov 3, 2012 04:12 PM
ndekens
Apr 4, 2009 03:50 PM
mytruck2
Dec 13, 2006 04:50 PM
