fuel pump problem
Chad,
Did you replace the fuel filter when you changed the pump? Why was the pump changed? Did it just quit working,....was it weak? Did you replace the wiring connector at the pump? Do you know what your fuel pressure is now?
If I had to make a guess I would say your fuel filter needs replacing.(based on the information you provided) I would try that first,.....then if it doesn't improve I would start looking into other areas.(air filter, tune up,etc.)
good luck, keep us posted.
Gator
Gator
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
mytruck2
Dec 13, 2006 04:50 PM
