Fuel pump recommendations?
As per my other thread, I'm in need to get a fuel pump.
Now I have read many threads here regarding pumps, and the the general favourable choice is either AC Delco, or Delphi pumps. I have an option of buying either, the Delphi pump cost $40 more, but honestly, at the price they are going for, $40 is like pennies lol
So my question is, do I just get the Delco pump? Or do I pay the little extra for the Delphi? Both seem like good pumps. Both of them come with the whole assembly (pump, pump chassis and sending unit), they both come with a new pigtail wiring harness, and o-rings. So, essentially they are the exact same package. I would just like to know which one has worked out better for people here.
Also, when I get the old pump out, I am going to save the chassis and conjure up something that I can solely use an inline pump. Seems like these things fail way too often to not try something a little more practical and easier to change...
I would go with the AC/Delco pump. I doubt that their failure rate is any higher than other OEM pumps. The main reason they fail is probably due to drivers letting the fuel level get below 1/4 tank on a regular basis causing the pump to overheat. Periodic use of Techron Concentrate Plus in the tank will also help prevent sulfur compound build-up on the sending unit which causes it to malfunction.
If you can find the AC/Delco cheaper, go with it.
Yep, just ordered up the AC Delco pump. Only hitch is it wasn't in stock, so it may take a week and a bit to get here. Oh well, leaves me plenty of time to tackle any other odds and ends I may need to address. I'll wait for it though. Ended up being $340 CAD shipped, that's for the whole module sender included!
If you maintain the fuel filter and don't run the gas level at less than a quarter tank then the pump should last quite a long time. (The pump is cooled by the gas it is submersed in)
You will never get a "puller" or siphon pump to make the same high fuel pressure that an in tank "pusher" style pump does. At least not in a reliable way.
But hey, I like working on cars, and I like thinking up new and original things to do, so when that time comes, I will definetly try it out...
So you've been tinkering with this eh?..cool. Keep in mind that the fuel requirement of your 4.3 will be beyond the capabilities of the standard 255 pump so you will need to use the 255HP pump.
"Running the tank low on fuel will overheat the pump" is a myth, it's not true. The return fuel line connects to the fuel pump module. The fuel travels through one of the spring loaded tubes and empties into the well that the pump is mounted in. If the engine is running, the pump is being cooled. Next time you take a pump out, check it out
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
"Running the tank low on fuel will overheat the pump" is a myth, it's not true. The return fuel line connects to the fuel pump module. The fuel travels through one of the spring loaded tubes and empties into the well that the pump is mounted in. If the engine is running, the pump is being cooled. Next time you take a pump out, check it out ![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
Oh I have my eye on a certain Walbro pump already... I honestly do think that the standard 255 will keep up to the stock 4.3, but I haven't really crunched the numbers yet... Just at a glance I've researched that the 4.3 on moderate throttle can use up to 45L/hr at ~55psi... Doesn't seem like that much of a task for a regular 255, but I'll find out for sure...
