Fuel Pump Relay
Old Sep 6, 2013 | 09:05 PM
RMBlazernut's Avatar
RMBlazernut is on a distinguished road
Default Fuel Pump Relay
I just got another 95 s10 blazer and im having a issue..I have no power to the fuel pump..My question is where is the relay located at on this truck. ive searched google and you tube and cant find an answer..google says its in behind the glove box but then they make a correction and say its on the drivers side..drivers side of what??:? its not under the hood..The only reason im asking is ..im not sure the relay is even in there..i checked behind the glove box and there is a relay panel there but no relay's are there..so that could be my entire problem..the last owner cut everythiong..battery cables..heater hoses, raditor hoses..the works.. i got all that fixed and i sprayed starting fluid in the throttle chamber and it starts so i know it runs, but i dont want to do that to often because it leans it out. any suggestion would be appericiated..i would like this to run this weekend..pics to come of it after she runs..Oh and my silver blazer i have a build on..it has a busted frame so its a parts truck for this one now.
Rick
Old Sep 7, 2013 | 07:17 AM
There has to be someone out there that knows where this thing is
Rick
Old Sep 7, 2013 | 09:59 AM
spittybays
Guest
Posts: n/a
All I can tell you is on my late 95 the fuel relay is in the glove box, behind a plastic clip cover. There are three slots two are used. Not sure which two.
Old Sep 7, 2013 | 11:10 AM
thanks..will start there
Rick
Tony H
Apr 16, 2014 08:36 PM
upblazer95
Mar 8, 2009 07:15 PM
bestes
May 31, 2008 03:16 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
