Fuel pump relay on '95
Old Jul 22, 2018 | 02:32 AM
Mike.308's Avatar
Default Fuel pump relay on '95
Howdy,
Some of You may remember I have another '95 Blazer of a friend. I've went a painful route from a dead (sized) battery, not working starter, improper plugs, damaged plug wires and the loose distributor cover....
For now, the car is cranking and I got a spark, but the plugs are bone dry. I guess it's the fuel pump.
I doubt if dropping the tank without having the car hoisted is possible, so I wanted to check if the fuel pump is getting the power and to measure the load (resistance) on the power lines. Oh, yes, this setup does not have a fuel port to test the pressure. Neither a relay box - the relays are here and there.
I've been browsing the Internet to find out a wiring diagram and locate the fuel pump relay. What I found pointed me to a middle relay into the gloves box, but it turned out t be a horn relay. I checked the other two with ammeter, they do not seem to be taking any current (one gets 0,05A, so call it nothing) and I don't know what devices do they control.
So, as far as I am not sure which relay is the fuel pump one, I cannot 100% tell the pump is dead. Could someone help me finding the fuel pump relay? Blazer seem to be built in '95 but has some of '96 stock parts (like a horizontal distributor).
Brgds, Mike
Old Jul 22, 2018 | 07:51 AM
chevyriders's Avatar
I know that 95 was sort of an oddball year for many of the electronics. Some of them stayed the same through 97 though.
On the 97 I had, there were 3 relays in the glove box also.
I forget the order of them, but they were:
-fuel pump
-blower motor
-horn
I know this doesn't answer your question, but perhaps you could use process of elimination with that information to find the correct relay.
Old Jul 22, 2018 | 03:36 PM
Mike.308's Avatar
-fuel pump
-blower motor
-horn
Thanks, that is an useful info.
The horn one I have already confirmed.
Blower one should be easy to find out - a power for coil is going be present whenever a blower is requested from a dash switch.
The 3rd one is the fuel pump.
Sadly that leads me to a conclusion of a dead fuel pump, and I still haven't figured out how to extract the fuel tank w/o hoist. And to be honest, this exact car is unbelievable neglected, I can hardly force myself to work on it. A true energy vampire thing.
As a side note - a 2" body lift seems to solve many problems with an access to pretty everything. In my own ride I can easily reach the connectors and plugs at top of the tank. They could produce such ones at almost no additional costs.
Cheers, Mike
Old Jul 23, 2018 | 03:59 AM
Mike.308's Avatar
Neither one of them is for blower in my case. I took all three out of the sockets and the blower is still running.
I've installed the right one - it remains energized, whenever I turn the key forward to ignition.
The left one gets energized when I turn to ignition, but falls off after a few second.
I'd say left one might be fuel pump primer, right one fuel pump regular supply. It seems I may need to pull the fuel tank out to figure out. Just (...) lovely.
Puffie40
Dec 24, 2014 09:04 PM
Chevy33
May 16, 2011 11:51 AM
bassman
Jan 6, 2011 05:13 PM
bassist
Aug 26, 2010 08:46 AM
Alex01tib
Mar 26, 2009 02:11 PM
