fuel pump replacement 96 4 drblazer
hey anybody know how big of a problem removing my tank will be?
what is part# for ac/and or delphi unit?
will very low oil press. cause cut off of fuel?
how should i test for this condition?
i parked and tried to start and non start .
cant hear pump running now.
starts with fuel poured in throtlle body
any help is good help thanks!
Fuel filter clogged?
I'd definitely check the oil pressure sending unit first. From what i've found with no/very low oil pressure the fuel pump will cut off when the engine is already running. I can't imagine it would lock out the fuel pump prior to starting though.
Fuel Pump
http://www.rockauto.com/catalog/rafr...1029507k997021
Fuel Pump
yes replaced fuel filter 2months back
check the fuel pressure with a gauge to eliminate certain things. jerry
BouncingRadical
14
11-27-2015 12:30 AM
jewag87
07-20-2014 05:05 PM
ned4spd8874
02-10-2011 10:48 PM
cide
11-07-2009 01:26 PM
mytruck2
12-13-2006 04:50 PM
