Fuel Pump seems to be bad
Old Feb 1, 2007 | 07:45 PM
CombatMedic's Avatar
CombatMedic is an unknown quantity at this point
Default Fuel Pump seems to be bad
Okay I took my blazer to the dealer today b/c I thought my remote start activated the passlock. They tell me that it didn't and the only thing wrong is the fuel pump. I told them to bring my truck home and I'll fix it myself. How do I test the fuel pump? It is in a 99 model. PLEASE HELP!!!
Old Feb 2, 2007 | 02:15 AM
filstoy's Avatar
filstoy is an unknown quantity at this point
Default RE: Fuel Pump seems to be bad
Assuming it's a 4.3, Can you hear it running ? Hook up a pressure gauge to the fitting at the back of the intake manifold.Turn ON the ignition leaving the engine OFF, the fuel pressure should be 415-455kPa (60-66psi) when the pump is running.
If it's not running, you need to check for voltage at the pump or trace it back from there. Could be a fuse, fuel pump relay , oil pressure switch, pcm etc.. Trace it back with a volt meter because it's too expensive just replacing parts. The meter don't lie.
Old Feb 3, 2007 | 01:34 PM
bdscholes71`'s Avatar
bdscholes71` is an unknown quantity at this point
Mine went out on newyears eve on a 98 4dr 4x4. If you jack it up and drop the spare you can get under there and unplug the fuel pump electrical connector. Have a friend cycle the ignition switch which should send voltage to your pump. You'll get 12 vdc for a few seconds if it's good. I can't remember which connections to put the meter on but a Haynes manual has a picture of it. Good luck.
Old Feb 3, 2007 | 05:44 PM
blazermanxx's Avatar
blazermanxx is an unknown quantity at this point
Before you do all that work, i was also told that my fuel pump went out or was going bad, what i did was replace the fuel filter on the drivers side, under the back door on the fuel line, and also replaced the fuel injectors and i was golden. Alot less work too...
however check to make sure you can hear the pump like prime itself first! and Filstoy is right about the voltage and PSI.
BouncingRadical
14
Nov 27, 2015 12:30 AM
spittybays
Nov 3, 2012 04:12 PM
Toby Hanson
Jun 25, 2011 01:49 AM
ndekens
Apr 4, 2009 03:50 PM
mytruck2
Dec 13, 2006 04:50 PM
