Fuel Pump Test
Old Oct 25, 2007 | 03:30 PM
jim45's Avatar
jim45 is an unknown quantity at this point
Default Fuel Pump Test
New to me 1998 Blazer 4dr 4wd. I have a no start condition. I have no fuel pressure at the Schrader valve. Engine cranks but won't start. Iswitched the relays (Horn & Fuel pump)in the main fuse panel underthe hood. Still nothing. I don't hear the pump come on when I switch on the
ignition. Searched the froums and I tried the banging on fuel tank tip, but't that didn't work.
My question is, before I drop the tank and replace the pump, I read about a red wire that I can
hook power to that bypasses the relay and see if the pump comes on. I cannot locate the "red wire"
Can someone please give me and idea where it may be and also did I miss anything before I drop
the fuel tank? Thanks
Old Oct 25, 2007 | 04:36 PM
Default RE: Fuel Pump Test
Bypassing the relay may or may not give you what you expect. Most often, this is a faulty pump, but could be caused by a broken wire to the pump. You really need to pull the electrical connection off of the pump and test the main power/ground leads. If you have power at the pump, then the pump is the problem.
Old Oct 25, 2007 | 06:59 PM
drperry's Avatar
Also, check the fuse, not just the relay, just incase...
Old Oct 25, 2007 | 07:19 PM
thegr81's Avatar
i agree with the previous my buddy had that problem with his blaze it turned out to be the pump good luck
Old Oct 25, 2007 | 08:16 PM
jim45's Avatar
Thanks for the info. If I can get to the connections at the pump I'll check for power.
If not, I'll just replace the pump, as it's probably the original.
Old Oct 25, 2007 | 08:19 PM
thegr81's Avatar
more than likely its originall alot of mine is and alot of everyone i know has all original parts. good luck with the repair
tjchevy59
Mar 22, 2022 02:36 AM
camohunter
Feb 23, 2014 06:08 PM
terbates
Feb 2, 2011 11:03 PM
Taz
Oct 17, 2009 12:21 PM
arrowsbydish
Dec 18, 2008 07:32 PM
