fuel smell
Old Oct 2, 2009 | 10:32 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Default fuel smell
For the past month or so I have had an off and on fuel smell issue. Near the rear wheel/rear door on drivers side I can smell gas sometimes and not other times. I cant find any wet spots or drips. The lines are rusty but I think that I would see fuel if it sprung a leak. The tank and evap canister look fine, and the vent above the spare tire doesnt have any fuel odor. It still runs the same no change in idle speed or quality. Any ideas would be appreciated.
Old Oct 4, 2009 | 10:04 AM
portcqb's Avatar
did I really already check all the things people can think of?
Old Oct 4, 2009 | 11:16 AM
rriddle3's Avatar
How's the gas cap seal?
Old Oct 4, 2009 | 08:31 PM
portcqb's Avatar
it still looked good I added some vasoline just in case on it also, no odor from the gas fill area.
Old Oct 4, 2009 | 08:40 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
Do you have the smell when the tank is full, 3/4, 1/2, 1/4, or does it happen completely randomly? Mine was leaking when it was over 3/4 at the top of the tank where the sending unit goes into the gas tank. It was missing the rubber o-ring under the lock. You have to drop the tank to inspect it though.
Old Oct 4, 2009 | 09:51 PM
portcqb's Avatar
it doesnt seem to matter it will do it when it full all the way down to an 1/8th which is as low as I run it
Old Oct 7, 2009 | 03:24 PM
mgkyle's Avatar
mgkyle is an unknown quantity at this point
Default Purge valve
There is supposed to be some sort of purge valve back by the gas tank (above the spare tire, on some years).
You might see if that valve is the source of your smell.
https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/po440-code-fuel-smell-6982/
Old Oct 8, 2009 | 12:00 AM
portcqb's Avatar
Yah thats the vent I checked above the spare, it doesnt smell like anything.
ckevroll
Oct 17, 2009 11:04 AM
chrisblaze
May 23, 2009 02:21 PM
bumsinthehouse
Apr 22, 2009 12:21 AM
pete c.
Dec 1, 2006 10:42 AM
Darrin A.
May 7, 2005 03:40 AM
