Fuel System Diagnosis- What should I do Next?
Old Sep 14, 2013 | 07:33 PM
  #21
porkfriedrice's Avatar
porkfriedrice is on a distinguished road
So I went to the dealer last weekend to see about that filler hose, and I guess you can only buy the hose along with the filler neck for $120, which they didn't have in stock. I was hoping they'd have it just so I could look at the hose, or that the parts guy would be experienced enough to know the size off hand. Nope.
Tonight I loosened the clamps on the hose to see how stuck they were. The end on the tank moves pretty freely, while the filler neck side is stuck on there pretty good. I used a screwdriver to see if I could free it up a little, and noticed how rusty the metal portion of the filler neck is. Now I'm wondering if I should replace the filler neck anyway since its so rusty. Pics below to show what I'm talking about. Do you guys think I should replace it or just leave it alone? I found it online for a little cheaper, but with shipping it's still ~$100.
Also, not to beat a dead horse, but the part that I circled in post #15 isn't a vent tube, it's a grounding strap. In one of the pics you can see where it attaches to the frame, just below the blurry hose clamp. So still a little confused on the venting system here.
Attached Thumbnails Fuel System Diagnosis- What should I do Next?-x6mgz27l.jpg   Fuel System Diagnosis- What should I do Next?-wvf1pdvl.jpg
Old Sep 14, 2013 | 07:49 PM
  #22
As rusty as it is, it won't be long before pin holes start showing up. Then you start getting EVAP DTC's and fuel leaks. If you're going to keep the vehicle, you might as well replace it now and be done with it.
Old Sep 14, 2013 | 07:58 PM
  #23
Yeah I figured as much. Crap, another $100. I assume replacement is pretty straight forward, just remove the housing bolts under the fuel door, unbolt filler neck from housing, and do the reverse to install? The ground strap is attached to it also I think. Sucks that this is a dealer only part.
Old Sep 14, 2013 | 08:09 PM
  #24
burned's Avatar
burned is on a distinguished road
Wreckers don't have those?
Old Sep 14, 2013 | 08:33 PM
  #25
I don't know, I'd be a little wary about getting it from a junkyard. I mean, if mine's this rusty wouldn't anything they'd have be in the same shape? I did a little searching on the local junkyards web pages and no one has it in stock. I kind of live out in the boonies so there aren't any junkyards close to me.
Old Sep 15, 2013 | 12:46 AM
  #26
AfterBurn99's Avatar
AfterBurn99 is on a distinguished road
If you can't source one, try and source something called POR15, it's an anti rust, hard as a rock, paint you can apply with a brush. It will stop the rust in it's tracks, but that should be a last resort.
Good Luck!
Old Sep 15, 2013 | 07:06 AM
  #27
Checked the website and that POR15 sounds like some amazing stuff! Available in a spray can too! I suppose it could be used along the rocker panels before painting, (similar to gravel guard). Thanks for sharing.
Old Sep 15, 2013 | 10:07 PM
  #28
I do a lot of resto's on cars/trucks. That stuff is the best thing since sliced bread. You can even spray the quarts/gallons if you mix it up with reducer, then you can spray it through a paint gun.
I have done countless frames, quarters, truck pans, floors, etc in this stuff. Little expensive, but worth it!
Old Sep 20, 2013 | 03:53 PM
  #29
Okay, so I just started and have already hit a snag. Haven't given up yet, but thought I'd post and see of anyone had any ideas while I mess around. Is there any way to get the fuel tank shield off without messing with the leaf springs or breaking it? The side tabs for the shield are keeping the the shield from clearing the springs. I've tried various ways of positioning it but so for no luck. Will keep trying, but if someone has an idea that'd be great.
Old Sep 20, 2013 | 04:25 PM
  #30
Got it out.. but cracked it slightly in the process. Not too bad, but hopefully I won't break it even more putting it back in.
