Fuel Tank Ground Strap HELP!!
Old Mar 2, 2014 | 06:00 PM
4x4Sandman's Avatar
4x4Sandman is on a distinguished road
Default Fuel Tank Ground Strap HELP!!
So i have a 1998 4x4 4door Blazer and i was under it the other day replacing the top half of the fuel filler neck and a braided wire fell off the frame and my friend told me it was a grounding wire for the fuel tank, DO I NEED THIS!?!?! WHAT HAPPENS IF I DONT REPLACE IT??!?!?! HELP!?!?
Old Mar 2, 2014 | 06:09 PM
It is not a ground for the fuel tank. It is for grounding static discharge to the frame when you refuel. For safety reasons, it needs to be there.
Old Mar 3, 2014 | 01:04 AM
4x4Sandman's Avatar
I have been looking everywhere and i cant find a place that sells them, do you have any suggestions?
Old Mar 3, 2014 | 01:32 AM
Diaita's Avatar
You should be able to go into most auto parts stores and get a ground strap the appropriate length. Worst case, a couple ring terminals and a piece of wire would suffice.
Old Mar 3, 2014 | 10:07 AM
4x4Sandman's Avatar
Thanks, And do you know where im supposed to put it? cause it just fell off and i have no idea where it goes.
Old Mar 3, 2014 | 10:12 AM
newguy's Avatar
Anywhere you can screw it to the frame, just sand the frame down dirst for a good connection
Old Mar 3, 2014 | 10:19 AM
01xtreme_chevy's Avatar
01xtreme_chevy is on a distinguished road
It bolts to the top of the crossmember (the crossmember behind your bumper) on the driver side of the vehicle. Takes a 18mm wrench to get off.
I had to replace my fuel pump and with a half tank of gas it fell down and snap the wire off. I just used a new electrical terminal and bolted back on. Fixed my issue though.
Old Mar 3, 2014 | 11:16 AM
newguy's Avatar
maybe 8 mm 18 is pretty big
Old Mar 3, 2014 | 01:11 PM
I may stand corrected on that one but it's the gas tank straps that I am thinking of that is 18mm for the bolt and the nut.
Old Mar 3, 2014 | 02:08 PM
newguy's Avatar
Gotcha
