Fuel Tank Leak
Old May 8, 2010 | 10:04 AM
beatleb95's Avatar
beatleb95 is on a distinguished road
Default Fuel Tank Leak
My 95 blazer has a seeping fuel leak on the bottom in the middle of the tank does anyone know of a permanet fix or must the tank be switched out. If the tank must be switched out what is the best spray lubricant for the high pressure fuel line fitting they are threaded like brake line. and a bit rusty?.
Old May 8, 2010 | 02:45 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
The have stuff to fix plastic gas tanks at the parts store. You don't even have to empty the tank.
Old May 8, 2010 | 05:37 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
the 95's came with steel tanks, and yes, if its leaking you have to replace the tank. the best penetrating oil i found that works great is PB Blaster, that stuff does wonders on rusted fittings and bolts! ( http://www.expeditionexchange.com/bl...r003%20027.jpg )
Old May 8, 2010 | 07:30 PM
beatleb95's Avatar
Default 95 blazer
Thanks to both of you changing the tank is the first thing i thought of. but the idea of something that might stop the leak since it is only a seaper. no gas goes on ground it is that light of a leak. but you wipe it and wait maybe a sec, and you will see it appear
mmalone120
Aug 22, 2022 08:47 PM
Smc
Nov 14, 2013 04:46 PM
wjdjake
Jul 17, 2011 02:06 AM
Bern'sBlazer
Apr 10, 2010 03:59 PM
