fuel tank strap bolts
I need to drop my tank to do a fuel pump. are the strap bolts that hold the tank in a pita to get to?
No- actually very easy to access! Prior to the job soak same with PB and have on hand a new tension bolt(for lack of a better term) cause you will need it! About $10 and then you can just cut the old ones off and do the job in about an hour or so! Just be careful of the plastic fittings at front of the tank-very brittle!
Originally Posted by step66
(Post 535986)
| All times are GMT -5. The time now is 01:22 AM. |
