Fuel Tank Wont Accept gas!!!
it was not the vapor line
I found out what was wrong when I talked to a friend at work . He said that blazers are prone to have to have the sending unit fail and that I should get a 5 gallon tank of gas and drive the truck untill I run out.
So when I did I filled it up and then started to drive with the trip meter on
I noticed that the digital would say that I have 78 Miles to go and the needle would only go up to 1/4 tank but when I drove around it would go to E and the display would go to LOW MILES so I drove it about two weeks untillI ran out and then took it to the gas station to fill up I was able to put a full tank in, so now all I have to get fixed is the sending unit I hope that this helps you out
Okay I have the same issue here with my 2002 Blazer. The only difference is that unlike you guys, lol, I'm not mechanically inclined. I'm also in a bit of a tight spot where I have roughly 1/4 of a tank of gas (well, maybe, I think my gauge lies to me, too) and commute 20 minutes to-and-from work every day, so I'm at a point where this needs to be done, but at the same time I'm very strapped for cash -- why is it always when I'm most vulnerable? lol
anyway, I'm getting a mixed vibe towards a solution here. I've read 2 or 3 of you guys discussing the vent possibly being collapsed, and I've also seen a mention of the Sending Unit and an Emit Vap switch.
Now, I can tell you that I've had an on-and-off situation where the SES would turn on and the code would be for an emit vap leak, which everybody told me was simply "gas cap". So based off that, could it be the switch? Sounds like that's what I'm hoping it is due to cost lol
Thanks again for any clarification.
It is the sending unit attached to the pump. Do like the OP and get a five gallon gas can, fill it up, strap it down somewhere and drive the truck until it runs out of gas.
I have a sending unit that gives me a low fuel light @ 200 miles and only 11 gallons gone. So I know that @ 18 gallons in the tank and 20MPG I can theoretically drive 360 miles on a tank. So I push 300 with the fuel light on for 100 miles.
No mechanical experience needed.
Justin
Justin
Well the sending unit and the emit vap valve were removed. This eliminated the SES code which has plagued me since the dawn of man, but it didn't solve the problem. Going to check the vent tube? Tomorrow morning. I'm just ready for this f'n thing to be fixed.
Tank will not accept Fuel
I have a 2002 blazer. Just bought it and when I went to fuel up an hour down the road it took 20 minutes to let it trickle in. The chev dealer told me that I need to purchase an entire tank along with all parts in order to fix the problem as the tank is sold as a complete unit. The cost for just the unit is $1,100.00. Anyone have a better suggestion. Thanks
-William
