Fun fun.... HELP
Old Jan 19, 2020 | 06:33 AM
Gilz's Avatar
Gilz is on a distinguished road
Default Fun fun.... HELP
Bought this 01 Jimmy a couple years back, Traded my diamond edition for a Pontiac TA about 15 years ago and regreted it. Anyway this project started with a bad hub assembly and now im here
Cv boots were toast, seals L&R no good, axle support bearings bad, no fluid just dirt and cv grease in the carrier
Now im here, diff. bearings, pinion bearings, being replaced with NTN does anyone know of a front diff. Rebuild manual of anykind, or have something that might be useful like backlash info, load specs, AAM ifs 7.25\" clamshell front having trouble finding any information
Old Jan 19, 2020 | 11:17 AM
Can you get your hands on a GM service manual?
Old Jan 19, 2020 | 11:38 AM
Gilz's Avatar
Yeah for around $150, was hoping I could find a free pdf version, or AAM manual. Did manage to find preload and backlash specs..but need to verify. Tons of info on any other differential.
Old Jan 19, 2020 | 12:53 PM
GeorgeLG's Avatar
You can try Mitchel1 DIY. They have the procedures and (I believe) the specs you are looking for.
George
Old Jan 19, 2020 | 01:18 PM
LesMyer's Avatar
Here's quite a bit of GM Factory assembly information (as the attachments). The menu is show to illustrate what I didn't attach. Are you really sure you want to get into this without all the special tools? I have done rears before with just a dial indicator, a wasted new pinion bearing (identical new bearing honed out to slide on/off the pinion for pinion depth checks), and pinion preload shims instead of a crush sleeve (how to reliably crush the sleeve with that much torque without the special tools) - but for the front of my Avalanche I just bought a used one on Ebay. Can't imagine splitting that front carrier apart many many times for gear contact pattern tests. Here you set pinion depth with a gauge and you're pretty much done. You are planning to replace the ring and pinion, correct? Undoubtedly they are worn if the diff was run dry and bearings are shot.
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 5, 2020 | 07:12 PM
Gilz's Avatar
Just buttoned it all up, have a small makeshift "shop" nothing fancy, shop press, pullers, etc. Got it built. Just finished u-joints, steering box, ptmn,idler, tierods, all new bushings, balljoints, hub assembly, calipers, hoses, rotors...
Propeller shaft, ugly as hell, guess its next
Old Feb 5, 2020 | 07:21 PM
Gilz's Avatar
Old Feb 5, 2020 | 07:23 PM
That's extremely clean... looks good.
Old Feb 5, 2020 | 07:32 PM
Gilz's Avatar
All worth it, took my time
Mike.308
Sep 9, 2018 02:04 AM
supermo26
Oct 10, 2017 09:44 AM
bvanfossen
Apr 29, 2012 06:44 PM
DaveRush
Nov 5, 2011 06:30 AM
rob1621
Apr 12, 2008 09:45 AM
