Gas Filter
Old Aug 21, 2011 | 06:17 AM
Chilimon's Avatar
Chilimon is on a distinguished road
Question Gas Filter
Tried changing my gas filter on my 2000 Blazer yesterday, the nut on the inlet side is so rusted, I can't break it loose, I even doused it with PB Blaster a couple times last night so I'll try it this morning again. I am not one to admit defeat but it sounds like it might go across the street to my mechanic. Does anyone have any tricks they used that might help me ?
Old Aug 21, 2011 | 08:30 AM
TouringMike's Avatar
TouringMike is on a distinguished road
Did you round off the hex of the nut?
Vice Grips is what I use when that happens. (This and a BFH are my best defences againt rust )
Sitting overnight may have helped the pentrant somewhat.
Good luck.
Old Aug 21, 2011 | 11:33 AM
RonJon's Avatar
RonJon is an unknown quantity at this point
When mine was frozen I disconnected the quick disconnect toward the motor. Then there's a single bolt that holds the plastic bracket on the frame with the filter in it and it routes the lines on the frame, remove the bolt, remove the lines from the plastic holder, slide the plastic holder off the filter (spit lube helps) and then unscrew the filter from the line. Now spray some PB Blaster on it and let it soak on, it's easier to break the nut loose with no filter on it - don't twist the steel line.
Old Aug 21, 2011 | 07:57 PM
Logan's Avatar
Logan is on a distinguished road
i cut min and just got a new line and nut at a local auto parts store. Then connected them with some fuel injection hose and used fuel injection clamps.
Old Aug 21, 2011 | 08:04 PM
Chilimon's Avatar
This is exactly what I was thinking about doing.
Old Aug 21, 2011 | 08:17 PM
Matty man's Avatar
Matty man is on a distinguished road
Vise grips or swapping out the line,, I tried a torch once,, didn't fair to well,, J/K!! Dont try this at home, I was a professional,,, We have the same issue in Ohio,, dang salt trucks,,,, keep soaking with PB blaster,, Matty man
starandrose
Sep 22, 2010 06:25 PM
trapperjohn4077
Jun 7, 2010 10:49 AM
degaine_designs
Aug 19, 2009 11:12 PM
SnowRemorse
Jan 4, 2008 11:26 AM
ForkliftJeff
15
Oct 4, 2007 07:46 PM
