Gas Leak
Old Apr 19, 2009 | 09:02 AM
louisd11's Avatar
louisd11 is on a distinguished road
Default Gas Leak
I just bought a 1997 Blazer 2 door and there seems to be a small leak around the gas tank. It also only appears to happen when you turn the truck off, so I'm guessing that it may be a fuel line. What do you guys think I should take a look at? I'm not familiar with Chevy's I'm more of a Jeep guy.
Old Apr 19, 2009 | 09:38 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
First you should make sure that it isnt leaking all the time which would be a sign its a tank leak. If it stops after awhile it it most likely one of the fuel lines if they look anything like mine do then it wouldnt take much to pop a hole in them.
Old Apr 19, 2009 | 09:53 AM
louisd11's Avatar
UPDATE: It appears it is leaking from the fuel line, where the rubber goes/turns into the metal. There is a plastic piece where I believe the leak is coming from. I am unsure if this is the return or sending line. But it is the closet one too you.
Old Apr 19, 2009 | 06:44 PM
The fuel pressure line is 3/8" and the return is 5/16", the vapor line could be 1/4" or 5/16". Dorman makes fuel line repair kits and most auto parts stores carry them. Cut out the bad section with a tubing cutter and match it up at the auto parts store. The new line connects to the existing line with a compression fitting. The worst part of the job is getting to where it's leaking, might have to drop the fuel tank etc.
NYCJUDGE
Aug 28, 2011 04:35 PM
starandrose
Sep 22, 2010 06:25 PM
trapperjohn4077
Jun 7, 2010 10:49 AM
degaine_designs
Aug 19, 2009 11:12 PM
SnowRemorse
Jan 4, 2008 11:26 AM
