Gearbox oil
Hi,
i have 96 blazer. i havent driven it about 6 months. one day I had driven few miles just before. opened my hood and saw gearbox oli leaking out of the pipe where you check oil level. whan i opened the nob there were about 5 inch fountain of oli. when i started the engine, oil level droped. leater when i stoped the engine oil level rise again to the top of the pipe. i thein its not normal - what should i do? M |
Is this your engine oil or your transmission fluid? Either way, that is not normal in the least.
transmission oli.
i was sugested to check trnasmission exhortation (i hope its the right word)(hole where air gets out of the transmission) could you tell me where to look for it. |
The transmission case vent is located on top of the transmission about 1/3rd of the way back from the bell housing.
so this vent is located between transmission and body :S - how can i get near it to check it out? - lifting the body is not an option :S
is there some kind of hach in the body or something ? |
| All times are GMT -5. The time now is 11:47 PM. |
