Getting engine code???
Ok, I just bought a 02 Jimmy SLS. The engine light just came on, so I pluged in my ODB2 reader. It dosnt work. IS there a spacific reader that works, or do I need to go to GM, or is there an electrical problem thats not allowing the ODB2 reader to turn on or scan the ECU???
Cool glad you found it. If your dash gauge reads properly, then it mostlikely is a problem with the ECT (engine coolant temperature) sensor which supplies the PCM with the engine temperature for use in determining the proper fuel mix.
NCSurvival
Jul 29, 2012 01:44 PM
tim68
Feb 1, 2011 08:39 AM
gio17vani
Oct 27, 2007 08:43 AM
