Getting nothing when key is turned
Old Mar 18, 2013 | 10:09 PM
bhsdrillr's Avatar
bhsdrillr is on a distinguished road
Default Getting nothing when key is turned
Blazer is a 96 with 4.3l
First off I think the batt is bad so I had it on the charger. Take it off and put it right in the truck
When I turned the key on for the first time I got some weird things happening. There was a loudish buzzing noise coming from behind/under the dash on the passenger side. The lights in the cluster were coming on..all of them the abs light, check engine, etc...
The rpm and speedo went up and down, were kind of bouncing I guess you could say.
Did that 2 or 3 times
Knew that wasn't right so I unplugged the batt to try and reset it, plugged it back in. Now when I turn the key on, none of that stuff happens. It's back to normal as far as the other stuff but when key is turned to start nothing happens at all. Headlights will turn on, dome and other accessories but when I turn the key absolutely nothing. No noises or clicks. Hooked up jumper cables and still get the same thing, nothing
I know it's long but any ideas would help a lot
Old Mar 18, 2013 | 10:12 PM
bhsdrillr's Avatar
can the battery be so bad, that even when getting jumped that it wont do anything?
I could hear the fuel pump before I unplugged the battery and hooked it back up, but now I can't
Old Mar 19, 2013 | 11:21 AM
jdespain's Avatar
Maybe a bad battery cable?
Old Mar 19, 2013 | 12:35 PM
bhsdrillr's Avatar
hmm idk maybe.....have a new alternator coming in Thursday and new battery also so once I get those in I can see what happens
Old Mar 19, 2013 | 05:24 PM
bhsdrillr's Avatar
Checked the battery just now and it's sitting at 12.5 from when I was messing with it yesterday. Still nothing when the key is turned.
Not sure what it's called, but can the setup on the steering column that you put the key in and turn go out? Anything simple that I can check? All the fuses in the interior fuse box were good
going to dive into it more this weekend
Will check the starter connections
Old Mar 20, 2013 | 11:03 AM
bhsdrillr's Avatar
been doing a lot of searching and sounds like it could be the ignition switch...going to check it out and will report back
Old Mar 22, 2013 | 02:39 PM
bhsdrillr's Avatar
any ideas...gonna try and work on it this weekend?
tried getting to the iginition switch, but couldn't figure out how to take the lever off for the tilt wheel...to get the plastic trim around the column off
Old Mar 22, 2013 | 07:50 PM
bhsdrillr's Avatar
New alternator and battery fixed it....starts like a champ now
Guess one was bad
Old Mar 22, 2013 | 09:35 PM
warthogdriver's Avatar
glad you got her fixed up.
sometimes if your stuck the tech section might be able to help ya out if its quite around here...happens from time to time.
morpho18
Nov 12, 2013 06:45 AM
Mr.T
Jan 19, 2010 09:24 AM
Irish10Hockey
Dec 4, 2008 12:48 PM
speakerwire
Sep 19, 2008 02:25 PM
sidewheeler
Feb 10, 2008 12:11 AM
