Getting po101 code?
Old Aug 17, 2008 | 05:20 AM
rockon_79_54's Avatar
rockon_79_54 is an unknown quantity at this point
Default Getting po101 code?
I have a 2000 blazer vortex 4.3 the service engine soon light comes on. The code reading is PO101 which is mass air flow or volumeair flow circuit,range or performance problem. Do you need to replace the maf unit or is there something else that can be causing this problem?
Old Aug 17, 2008 | 01:05 PM
Default RE: Getting po101 code?
I would first try cleaning the MAF sensor. You must use a sensor safe carbon cleaner or a MAF specific cleaner (a bit safer) to clean it. I remove the aluminum pieces off either side of the MAF and then spray the elements with the cleaner. They should clean up to a silver, almost white color. If they are tan, they are still dirty. You MUST be careful. Break a wire and the sensor is trash.
Old Aug 19, 2008 | 05:27 PM
Thanks alot it's works great saved me alot of money! Ron
nharner
Nov 20, 2011 10:10 PM
wayneaaron
Aug 30, 2010 10:12 PM
xtremefirefighter
22
Nov 11, 2009 06:26 AM
gio17vani
Oct 27, 2007 08:43 AM
Bigblock396
Jul 18, 2007 09:49 PM
