got a random clicking noise
Old Dec 18, 2007 | 08:53 PM
mysssticghost's Avatar
mysssticghost is an unknown quantity at this point
Default got a random clicking noise
hey guys, i have a random clicking noise from behind the glovebox it does it from time to time. at times it sounds just like a blinker click, and at other times it kinda sounds like an abs module activating. any ideas on what could cause this random noise.
Old Dec 18, 2007 | 09:15 PM
blazerboy30's Avatar
blazerboy30 is an unknown quantity at this point
Default RE: got a random clicking noise
Anything acting up? If not..I wouldn't worry about it. I can hear the same noise on mine from time to time.
Old Dec 18, 2007 | 09:20 PM
TripleBlackBlazer's Avatar
I'm 99% sure my clicking is due to a bad multi-function switch. Does the clicking noise stop when you step on the brake pedal? Unfortunately, mine doesn't effect the operation of the brake lights so I don't think it is eligible for the factory fix.
Old Dec 18, 2007 | 09:37 PM
i am not sure if it is affecting anything or not. as far as brake lights i guess they are still on. i am driving so hard to tell. i do notice it more when i am stopped at a light or something. also, i can make the clicking sound by wiggling the turn signal lever. not the fast clicking but the one thta sounds like a signal is on.
Old Dec 31, 2007 | 05:15 PM
UtahZR2's Avatar
UtahZR2 is an unknown quantity at this point
I share your frustration and problem. I never noticed any problem before a "recall" replaced the multi-function switch inthe steering column. Now I think my Blazer could be a test fixture for Bosch relay torture tests. A lot of the info that I have found points to this switch, I have found them several places and even though I dislike pointing to Ebay as a parts source I have found the switch on there for about $110 plus shipping.
Old Jan 2, 2008 | 10:58 AM
*Moving to 2nd Gen Tech*
Old May 8, 2008 | 07:35 AM
greenlantern77's Avatar
greenlantern77 is an unknown quantity at this point
so if the clicking stops when you press the brake pedal, does that point to the multi-function?
also, i saw the recall for the 2000 but i have a 99 and did not see any recall for that year.
note-i am also posting on
https://blazerforum.com/m_52970/tm.htm
trying to figure out how to remove the multifunction
Old May 12, 2008 | 11:25 AM
dont worry about it, i figured it out myself
tdbone1
Dec 4, 2012 07:44 AM
dj00140
17
Nov 29, 2010 10:06 PM
Blazinflaboy
Jun 22, 2010 09:03 PM
ZLover4Life
Mar 9, 2008 03:48 PM
blazergirl15
Aug 28, 2005 11:17 PM
