Grinding noise in back
Old May 30, 2018 | 01:28 PM
man0steel's Avatar
man0steel is on a distinguished road
Cool beans......I'm a G80.....guess I will need to fix what I have. Is this the default for a ZR2?
Old May 30, 2018 | 01:45 PM
Rusty Nuts's Avatar
Yes, it's part of the RPO code ZR2 "off road" options package.
Old May 31, 2018 | 06:17 PM
N. Jensen's Avatar
Originally Posted by chevyriders
The shoop shoop noise makes me think wheelbearing.. but that doesn't seem like excessive play in it. How's your backing plate look? Is it bent or rusted and stuck in the caliper a little bit?
I'd try to spin it by hand and listen/search out the noise, maybe have someone lightly press the brakes while you do.
Another thought is a warped rotor hitting the backing plate or something else.
That backing plate is a real bear to get to.
Mine rusted bad, and would not stop making those wretched noises....no matter how many times I smashed it with a hammer!
Old May 31, 2018 | 08:50 PM
chevyriders's Avatar
Yeah, if I remember correct you have to pull the axle shafts to change the rear ones.. I think when i did them on my first blazer they were so rotted i basically pulled them off, and cut slots in the new ones so I could put them on without pulling the shafts lol.
Old May 31, 2018 | 09:05 PM
N. Jensen's Avatar
They make new ones that are two pieces.
I assumed I wouldn't need to change them in another 20 years... Guess we'll see! Lol
Old Jun 1, 2018 | 07:48 AM
man0steel's Avatar
So how does the backing plate make this noise, mine appear to be in pretty good shape with a little rust and feel structurally sound and not flimsy at all. If this is my issue I will be one happy camper.
Old Jun 1, 2018 | 08:27 AM
They get bent or distorted and rub against the rotor. Make watch in between the rotor and backing plate, spin the disc and make sure it's not contacting or abnormally close in any areas
Old Jun 1, 2018 | 11:56 AM
man0steel's Avatar
That's not it.........darn it. I thought there was another issue from previous threads, the backing plate was actually the second thing I checked after the pads.
Old Jun 1, 2018 | 03:21 PM
Zenith's Avatar
Zenith is on a distinguished road
Well then.......sounds to me like the wheel bearing. Even if you can't duplicate the sound with the wheel off the ground, putting weight back on it will most likely be the bearing. If its making that much noise, don't overheat or stress the bearing to much you will end up with a real mess on your hands, like replacing the axle and taking a chance of debris going into the rear end gears.
Old Jun 15, 2018 | 11:08 AM
Zenith's Avatar
Did you ever find out what the problem was?
The cool thing about these forums is sharing the solutions or progress if you could, as this benefits us all greatly.
