grinding noise..sounds like its comming from my dash
Old Apr 4, 2010 | 09:47 AM
wood0470's Avatar
wood0470 is on a distinguished road
Angry grinding noise..sounds like its comming from my dash
i have a 96 blazer 4x4...it sounds like a wierd grinding noise comming form the dash. when i apply the gas it seems to go away..but at idle or when i remove my foot form the peddle..it returns....soooo annoying its driving me crazy..can anyone help me with this PLEASE...what the hell is it and has anyone had the same problem
Old Apr 4, 2010 | 09:53 AM
DaveC's Avatar
DaveC is on a distinguished road
believe it or not it is most likely your pcv valve that is causeing this noise. i had the same issue and it bugged me forever.... go under the hood with the engine running and reach down to the pcv valve and feel it, it is probably vibrating like mad... replace for 3 bucks and i bet the noise goes away.
Old Apr 5, 2010 | 07:05 PM
wood0470's Avatar
wow ill try that thanks for the advice...ill let you know haow it works out...thanks again
Old Mar 28, 2011 | 07:36 PM
gnpower's Avatar
gnpower is an unknown quantity at this point
I have the exact same annoying issue. I was very sceptical about the pcv valve fixing the issue, but for 2.99, I gave it a try. As I suspected, after my new pcv install, the noise is still there. Has anyone come across a fix for this issue?
Old Mar 28, 2011 | 08:00 PM
It isn't so much the valve itself, but the vacuum line from the PCV valve resting on the cruise and/or throttle cables. If you just replaced the valve and didn't check for clearance along the length of the PCV vacuum line, you didn't address the issue.
Old Mar 31, 2011 | 11:29 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Thanks. I checked mine. It was unplugged from thevalve cover and I rerouted the vacuum tube also. Hopefully that cures it.
Bigjoe1986
22
Dec 2, 2015 04:29 PM
Vovin
Jul 10, 2015 07:10 PM
blazer485
Oct 20, 2014 06:59 PM
builder125
Oct 7, 2009 10:33 AM
napalm dan
Apr 17, 2007 12:53 AM
