guages going crazy with codes
Old Nov 20, 2011 | 12:19 AM
mxdave91's Avatar
mxdave91 is on a distinguished road
Default gauges going crazy with codes
the other day in my 98 blazer my oil pressure gauge went to zero and the cel came on. I got a code p0300 and p0101. The oil pressure gauge started working again but then my fuel gauge dropped to empty and my battery light came on. I shut the car off, waited a minute then fired her back up and everything is working fine. Also I noticed that sometimes when I floor it the lights get dim and it gets real sluggish and runs rough, but only when I floor it. After a short while it clears up. Please tell me where to begin. thanks
Old Nov 20, 2011 | 04:43 AM
dobyken's Avatar
dobyken is on a distinguished road
The first place I would look is the battery terminals...clean and tighten. It could also be a loose or broken ground wire. I had a similar issue once and it turned out to be a loose battery ground cable.
Old Nov 20, 2011 | 01:18 PM
mxdave91's Avatar
I'll check the battery and all grounds. I'll let you know what I find.
abadinalbany
Apr 16, 2011 11:31 AM
bigjoewebb
Jan 27, 2009 09:36 AM
mikeesho1
Oct 26, 2007 12:31 AM
drperry
Jul 4, 2007 04:25 AM
