Handbrake / Parking brake help
Old Feb 7, 2007 | 02:59 PM
blackknight's Avatar
blackknight is an unknown quantity at this point
Default Handbrake / Parking brake help
I'm needing to tighten up the handbrake on my 2001 Blazer for it's safety inspection. Can anyone advise me on this? Thanks.
Old Feb 7, 2007 | 09:49 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Handbrake / Parking brake help
Look under the truck where the front cable connects to the 2 rear cables, there should be a nut that you have to tighten. There is also an adjustment under each rear rotor for the parking brake shoes at the bottom where the cable attaches. How loose is it? How many miles are on your truck? Korey
Old Feb 8, 2007 | 03:27 AM
Chevy Lover's Avatar
Primary adjustment is the park brake shoes. If the shoes are adjusted correctly, you should not have to adjust the cable.
You might need to remove the rear rotor and check for a worn parking brake shoe, adjust it and then put the rotor back on and test it.
I always ajust them so that the wheels can't be turned by hand when the brake is applied about 4 clicks, then make sure they spin free when the brake is released.
[IMG]local://upfiles/2910/43C4F1B17D5B49E2AB01BAA493F4C9A2.gif[/IMG]
blazer2554
May 16, 2012 10:29 AM
hitmanK47
Dec 3, 2011 04:33 PM
okiedoak20
Jan 9, 2011 06:11 PM
dailydriver
Nov 19, 2010 11:26 AM
xderkax
Jan 14, 2010 11:38 PM
