Hard starting after sitting 01 zr2
Old Sep 5, 2015 | 10:39 AM
someone11's Avatar
someone11 is on a distinguished road
Originally Posted by er0ck273
if you only tested at the shrader valve near the distributor, you are only testing regulated pressure, set by the fuel pressure regulator, so the pump may be fine, without testing at the fuel filter, you cant determine the fuel pumps psi its sending to deem it within spec or failing to push the correct pressure
Right, but itll be quicker to take it to him and have him run the tests than it will be for me to sit here and wait for the parts to be shipped to be able to run the test at the fuel filter.
Also what are the chances it could be a fuel pressure regulator? I feel like it doesnt show those symptoms but im not sure.
Old Sep 5, 2015 | 10:47 AM
er0ck273's Avatar
er0ck273 is on a distinguished road
apparently the fpr go bad in these things, especiall with the old style injectors, not sure if you have the upgraded model or as i call them, the dud model, i had the dud and upgraded to the newer style when my fuel injectors were clogged.
Old Sep 5, 2015 | 12:01 PM
someone11's Avatar
Fuel injectors are stock as far as I know.
Old Sep 10, 2015 | 10:06 AM
someone11's Avatar
New fuel pump put in yesterday, no cost to me. Let it sit all day and overnight, started up fine this morning. Guess it was a lemon fuel pump right from the box.
Old Sep 10, 2015 | 06:10 PM
er0ck273's Avatar
thats good to hear! as for me, im screwed i cant figure it out on my end.
er0ck273
70
Dec 4, 2014 07:08 AM
Kmac81
Aug 11, 2014 08:21 PM
Kmac81
Aug 11, 2014 08:17 PM
swanman35
Mar 15, 2013 01:17 PM
