Hard starting when HOT!!!
Old Jul 29, 2007 | 11:37 PM
cliff191's Avatar
cliff191 is an unknown quantity at this point
Default Hard starting when HOT!!!
The Blazer (1995) always starts great when cold, bit now with the outside temps near 100, the truck is very hard starting after being driven for a while. The temp gauge is not out of the "Normal" range. The truck runs fine once restarted. Any ideas?
I am going to do the whole plugs/wires etc this weekend but am hoping for a bit more insight.
TIA
Old Jul 30, 2007 | 12:09 AM
Chevy Lover's Avatar
Default RE: Hard starting when HOT!!!
I wonder if maybe you have a leaking injector causing a flood condition.
If you had an internal fuel leak and the engine was cold it could use the extra fuel for starting, but if the engine is hot it wouldn't need the extra fuel.
Have you tried pushing the gas pedal to the floor when it's hot (clear flood mode) to see if it starts easier that way?
Old Jul 30, 2007 | 11:55 AM
hogspeed's Avatar
hogspeed is an unknown quantity at this point
Is it a hard start condition or an "extended cranking" situation? If you crank it for a long time and it starts, it possibly could be a leaking injector situ. Try putting your gas pedal to the floor to see if that clears it out (you have to push the gas pedal all the way down), crank for a few seconds, then let your foot off the pedal and keep cranking.
There are a lot of possibilites, maybe you can do some tests and give us more to go on...
Mandrwj
Apr 10, 2011 07:32 PM
largeteddybear2000
Feb 26, 2010 09:26 AM
ravenhurst
15
Apr 26, 2009 07:53 AM
chevydude_18
Mar 24, 2008 02:17 PM
chevydude_18
Mar 23, 2008 09:58 PM
