Harmonic balancer will not go on all the way.
I had to rent the puller/installer kit from Advanced Auto. I couldn't get mine on all the way either. Tapping it with a rubber mallet didn't work, plus I was risking hitting the radiator.
I rented the kit which is free (just put a deposit in) and it worked like a champ.
That is bad news. I would remove the front end and see if I could use a nail punch to tap the broken bolt in reverse. If that didn't work, I'd drill it out. Replacing the crank is a serious undertaking. It's worth giving these other things a try first.
For future reference I think there is a torque spec for a balancer installer. I wouldn't imagine it would be much over 70 ft. lbs, which I think is the spec on the crank bolt itself. Also the shop manual mentions it's a good idea to grease the crank when installing the balancer.
Additionally, if you put enough torque on that to snap the installer bolt, if you get it off you may want to consider the $50 bucks for a new balancer.
Katmandu
Aug 22, 2009 10:50 PM
