Has anyone bought a remanufactured Spider injector assembly from rockauto before?
I have purchased from rockauto.com, well known brands and low prices.These days its hard to find parts made in the good old U.S.A. but they are out there. Stay away from imported crap. Example, just rebuilt my entire front end myself and took it to the alignment shop.While there the mechanic said i had a little play in the pass. side hub bearing, i said o.k. ill take it home and come back.Went and purchased a hub bearing and put it in and returned to the shop 3 days later(had to drive it to work ) . The mechanic said the wheel was about to come off and i was better off with the old unit and that was after 240 of commuting. Took that one back and got a timken hub bearing MADE IN USA . no problem since. Had problems with foreign motor mounts(premature failure ,4 months) also.
i want to replace everything in there. the spider and the fuel line nut kit? is that whats its called? is there anything else i can replace in there? the fuel pressure regulator comes with the spider right? are there any o-rings that i should buy to?
the spider assembly comes as a complete unit with new o rings for the fuel return lines, the FPR is also attached to the spider..most parts stores wont know what a nut kit is lol but yes thats what the fuel return lines are called.
there is also a valve on the back of the intake that is used to measure the fuel pressure, is that valve included with the nut kit? my plastic cap is missing and im afriad there maybe dirt in there so i want to replace that too. so does it come with it? or is it sold separatly? and will the little black plastic cap come with it? thanks
