Hazzard light switch
Old Aug 27, 2011 | 01:07 PM
janddcunningham's Avatar
janddcunningham is on a distinguished road
Default Hazzard light switch
Guys i have a question. My 1997 lt 4x4 blazer has not had break lights for a while and i found the article on the bad hazzard switch i was going to but a whole new assembly but was wondering if replacing this switch for 20.00 bucks would woek for me?
So i messed around with the switch and my breaks flicker and if i hold the switch an 8th of an inch to the right they work. But i saw some smoke role out of it i am a bit concerned. What do you guys think?
Old Aug 27, 2011 | 02:11 PM
DaddysBlazer's Avatar
DaddysBlazer is an unknown quantity at this point
You can pull that switch shraight out and it shoud be fine without it and yes the thing is only 20 bucks. An easy repair.
Old Aug 27, 2011 | 04:11 PM
The PN listed in the how-to is for the 98+ trucks, not for the 96-97 trucks. Not sure if all of the steps apply...
Old Aug 27, 2011 | 05:57 PM
Well stink that is just my luck ok so i took a trident gum box and folded it and wedged it between the switch and the casing and i have lights so i am thinking easy cheap fix right?
Old Aug 27, 2011 | 10:25 PM
Ok from what i have read and researched it is the same for 95,96,&97 will keep digging before i do anything thank you guys you are the best
Old Aug 28, 2011 | 12:32 PM
kristoph30's Avatar
kristoph30 is on a distinguished road
Well the magic smoke you saw confirms your suspicion that the switch is bad.
The trident box will make great kindling for the upcoming fire.
REPLACE THE SWITCH.
Old Aug 30, 2011 | 03:48 AM
G-FLo's Avatar
G-FLo is on a distinguished road
I have the same issue , tried an old switch then put in a new one .. no brake lights regardless .. But mine works if I pull the switch towards the steering wheel so I fitted some folded cardboard behind it and works like a charm for now .atleast i have brake lights .. Possibly might need to swap out the whole multifunction switch .
Old Aug 30, 2011 | 08:13 AM
Hey thanks for replying i believe at this point i am going to buy the whole assembly. No need to waste 20.00 on a switch if that is not going to fix it. Now figuring out if i can do it myself.
Old Aug 31, 2011 | 09:59 AM
G-FLo's Avatar
I am no mechanic but do anything and everything I can before I fork over the money to someone else todo it . And basically I didnt have right tools to remove . You will need certain security bits and possibly have to remove steering wheel or atleast plastic behind the airbag area to access the torx screws in the column . But I havnt done it or seen a how to so I could be mistaken also . Goodluck it really a bitch figuring out gremlins thank god for this forum ..I'd be lost
swd1978
Aug 21, 2011 12:52 PM
95blazer49660
Apr 20, 2009 07:51 AM
JediKnight2
Sep 11, 2008 07:58 PM
battykoda
Nov 28, 2007 03:35 PM
kccapt
Nov 23, 2005 01:34 AM
