Head Bolt Torque Specs. and Sequence
Old Feb 14, 2010 | 12:27 PM
brians1bad72's Avatar
brians1bad72 is an unknown quantity at this point
Default Head Bolt Torque Specs. and Sequence
I have a 2001 Blazer 4.3l looking for torque specs and sequence for the heads. I am im the middle of the job right now. Thanks.
Old Feb 14, 2010 | 12:55 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
http://img341.imageshack.us/img341/82/cylinderhead.png
First Pass In Sequence - 26 ft-lbs
Second Pass In Sequence - 44 ft-lbs
Final Pass In Sequence - 66 ft-lbs
Old Feb 14, 2010 | 01:14 PM
Thanks Ryan, thats just what I needed.
Old Feb 14, 2010 | 01:27 PM
no problem
Old Apr 23, 2010 | 01:23 PM
actconstruction's Avatar
actconstruction is on a distinguished road
Default Head bolts 99 Blazer
Ryan, is this correct also for a 1999 Chevy Blazer 4.3L? 1996-2004 should be the same, even though they changed the milling once in that time period, right? And it's the same torque for all the bolts? I only ask because my Haynes manual shows:
Pass 1: all bolts: Torque to 22 ft-lbs.
Pass 2: short bolts: Tighten an additional 55 degrees
Pass 2: medium bolts: Tighten an additional 65 degrees
Pass 2: long bolts: Tighten an additional 75 degrees
Not sure why they chose to describe it that way, but what the hell, man. This method seems far too complicated and prone to error. That's actually what brought me to this post. The last time I had to do head gaskets on this model Blazer, everything worked out okay, but certainly not simple or accurate to make this type of measurement under the hood. Thanks a lot in advance.
Last edited by actconstruction; Apr 23, 2010 at 01:25 PM. Reason: Oops. Ommitted data.
Old Apr 23, 2010 | 03:26 PM
That is the 'new' bolt tightening. For on vehicle installation, use what Ryan posted above.
Old Apr 24, 2010 | 01:24 PM
Thanks for the always solid information, guys. Keep up the good work. This forum is great!
Old Sep 19, 2010 | 07:38 AM
mnjim's Avatar
mnjim is on a distinguished road
Smile
Thanks from here too. I'm in the middle of the same kinda project.
Old Jan 6, 2011 | 08:16 PM
rcravincase's Avatar
rcravincase is an unknown quantity at this point
so youre saying that its ok to reuse the stock bolts? ive always known of tty bolts needing to be replaced once theyve been torqued
Old Jan 7, 2011 | 02:33 AM
UberFail's Avatar
UberFail is on a distinguished road
Don't reuse.... its just that easy. BUY the new ones and save the piece of mind knowing you're not using previously stretched out bolts. if you're really that cheap that u won't pay the few bucks it costs for the set of bolts, you may just end up paying a HELL of a lot more when you do serious damage to the engine. BE SMART and use new bolts - its "Just that Easy!"
