headlight adjustments
i was just wondering how to adjust the height of my low beams on my 97 blazer. The drivers side is higher then the passenger side? thank u
RE: headlight adjustments
I'm not all that sure on the '97, but I believe the height adjuster is right above the headlamp housing. You'll need to pop your hood to access them. On my '00 Bravada, it takes a 6mm socket to fit over the inverted torx fitting. Mine were too stuck to attempt to use the T10 torx bit that is in the end of the bolt. Turn clockwise to adjust up and counter clockwise to adjust down.
