headlight adjustments
Old Dec 30, 2006 | 07:03 PM
blazer909's Avatar
blazer909 is an unknown quantity at this point
Default headlight adjustments
i was just wondering how to adjust the height of my low beams on my 97 blazer. The drivers side is higher then the passenger side? thank u
Old Dec 30, 2006 | 07:46 PM
Default RE: headlight adjustments
I'm not all that sure on the '97, but I believe the height adjuster is right above the headlamp housing. You'll need to pop your hood to access them. On my '00 Bravada, it takes a 6mm socket to fit over the inverted torx fitting. Mine were too stuck to attempt to use the T10 torx bit that is in the end of the bolt. Turn clockwise to adjust up and counter clockwise to adjust down.
g_mike
Sep 19, 2010 02:49 PM
kiwiblazer
Oct 15, 2008 02:22 AM
stevenf
May 7, 2008 11:29 PM
Tippman7641
14
Feb 21, 2008 10:57 AM
mdehoogh
Jan 16, 2008 11:28 PM
