Headlight Issue
Old Jun 2, 2009 | 12:53 AM
Emms1979's Avatar
Emms1979 is on a distinguished road
Default Headlight Issue
Hello All,
I'm new to the site, and am hoping someone can help me out. I have a 2004 Chevy S10 Blazer 2dr, and I recently had a headlight blow. I replaced it only to have other motorists furious with me cause they think that i'm high beaming them. I initially thought that maybe i bought too bright of a bulb and went back and bought the standard slyvania blub. However, once again I'm getting motorists who after i drive behind them, will move over, tail me and high beam me. I notice that the light beams in an upward direction, is there a proper way to install the bulbs? The piece that the blubs plug into has three prongs on it with one being thicker then the other two, allowing it to fix exact in the headlight case. I'm not driving with my high beams on if anyone is wondering either. Anyhow, I have no clue, any help is GREATLY appreciated.
Old Jun 2, 2009 | 01:02 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
installing a new bulb is incorectly is pretty imposible due to the three prongs you decribed, but its possible to intall the headlight itself incorrectly which it sound like you did. so go out to your blazer and take the headlight back out and also remove your grill(makes the process alot easier) then youll notice to arm type things on the back of the headlight those arms have a tab on the thatll go into 2 holes in the core support, slide the tabs into the core support then intsall the headlight like usual and your problem will be taen care of.
Old Jun 2, 2009 | 01:22 AM
Emms1979's Avatar
Thanks I'll definitely be taking care of that tomorrow.
Old Jun 2, 2009 | 01:27 AM
mikeinwi's Avatar
yup no prob, once you get everything off youll see how easy it is i tried finding a picture or diagram for you but i couldnt find anything that was decent
Old Jun 2, 2009 | 06:47 AM
x2 on not getting the headlight housing into the slots on the bottom. It is quite common.
bubs71
Oct 14, 2010 07:17 AM
blazin0299
Aug 11, 2009 06:39 PM
rpfpdz612
Feb 27, 2009 06:50 AM
djmiller
Jan 11, 2008 01:48 PM
88jimmah
Sep 22, 2007 12:51 PM
