Headlight Switch will not work
Old Mar 17, 2011 | 11:02 AM
acblenc's Avatar
acblenc is on a distinguished road
Default Headlight Switch will not work
Hey I have a 1999 chevrolet blazer 4x4 4 door 4.3 engine. I hit the dome override switch 4 times and my headlights still will not turn off. I replaced the headlight switch and my headlights still wont turn off ,my friend said some thing about a bad relay switch behind the glove box but i have no idea how to get to it any help would be great thanks -Alex-
Old Mar 17, 2011 | 11:08 AM
If your truck was originally spec'd for sale in Canada, this trick does not work.
Old Apr 30, 2011 | 09:53 PM
acblenc's Avatar
It was not spec'd for canada.
Old May 1, 2011 | 08:57 AM
bonecrush1's Avatar
bonecrush1 is on a distinguished road
turn off your truck, hit the parking brake turn on the truck, with the headlights off now check if the switch works. pull the parking brake, and the headlights stay on at all times
warthogdriver's Avatar
i have a 99 and it wont work like that either. i did have a 2000 at one time and it worked like that.
it might be a model year issue.
maybe swap in a switch from a 2000 or newer??
or you could just disable the daytime running lights (d.r.l), there is a relay in the power block in the engine bay that you can access and bend the prong back to disable the d.r.l
i have them disabled but still use the auto-head light feature for night driving....couple of options for you
"..........there is a headlamp relay (5 pins) located in the engine compartment or near the steering column, and if you bend over one of the coil pins, #85 or #86, or the normally open contact #87, that will disable the DRL. (#30 and #87a are needed)....."
DRL and AHL "how to" - S-10 Forum
Flyfishen
Sep 19, 2016 11:07 AM
bubba14731
Sep 10, 2012 12:19 PM
bertaguy
Sep 19, 2010 09:21 AM
ussexplorer
Apr 16, 2010 04:49 PM
hantayo13
Jan 12, 2008 12:34 PM
