Headlight don't work????
Old Sep 18, 2010 | 01:49 PM
bertaguy's Avatar
bertaguy is on a distinguished road
Default Headlight don't work????
My daytime running lights work fine but headlights don't come on????
Bulbs have all been replaced.
Any suggestions??????
Old Sep 18, 2010 | 02:11 PM
bksowers1's Avatar
bksowers1 is an unknown quantity at this point
The DRL are using your high beams. So my suggestion is to check the headlight relay or the fuse.
Old Sep 18, 2010 | 03:14 PM
LannyL81's Avatar
Could be the headlight switch...check that as well. Problem is that you have to take the dash front off to get to the darn thing. You can tell its bad if there is a brown area where the connector plugs-in.
Old Sep 19, 2010 | 09:21 AM
bertaguy's Avatar
the fuses all look ok and i can feel the relay click when the headlights turn on. maybe i'll check the switch in the dash see if there are any isssues there.
thanks for the info!!
project85
Jan 15, 2015 03:23 PM
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
KA3AX
May 4, 2006 10:50 PM
khalid_20879
Dec 28, 2005 08:47 PM
blazerj
Aug 24, 2005 08:24 PM
