Headlight system always on
Old Nov 7, 2009 | 05:44 PM
jackdaroofer's Avatar
jackdaroofer is on a distinguished road
Default Headlight system always on
I must have done something
Head;ight system, not DRL, comes on when I put key in ignition and stay on even while cranking and strtimg engine.
This is a 2005. it just started doing this. Did I push something? I have read that there are some switches that if you push them several times...things happen.
Thanks
Old Nov 8, 2009 | 12:33 AM
ABN31B's Avatar
Sounds to me like you have a short somewhere. Like your vehicle is reading your headlights as on all the time. from the point your key goes in until removed. may want to look into a new junkyard light switch, or do the right thing, find the resistances and what not, volt meter that bad boy, and be sure, or just drop $5 on a junkyard switch...
Old Nov 8, 2009 | 09:08 AM
Could be a faulty light sensor on the dash.
Old Nov 8, 2009 | 11:45 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
A DTC could also cause it. I had a few U codes from when I swapped in a new air bag module. The headlights were always on, until I cleared the codes with a tech 2. Everything has been working properly since then.
Old Nov 8, 2009 | 06:57 PM
Thanks guys
Problem seems to have solved itself for the moment. I went out last night to store. On the way I started playing with the headlight switch...dome overide...the lights went off while moving. I quickly turned them on with the switch and that was seemingly the end of the problem.
Mow DRL come on only when in gear and headlights work on switch
Maybe it is a gremlin that might return. I'll keep your suggestions in mind
Thanks again
liltittle62
Dec 26, 2010 03:55 PM
98blazer12
Oct 10, 2006 11:20 PM
Philly Assassin
Jan 4, 2006 06:39 PM
oldsmobuick420
Nov 19, 2005 04:30 PM
swissmiss
Jul 10, 2005 01:16 AM
