Headlight wiring problem
Old Nov 15, 2007 | 10:05 AM
rocket_rn25's Avatar
rocket_rn25 is an unknown quantity at this point
Default Headlight wiring problem
I had a accident in rt. front bending fender and pushing the back wall in a little which the headlightattaches to. I bent that back out, spliced in a new plug for my head light, and now the head light on that side and both high beam lights come on dim when headlights are on. Drivers low beam works fine. If either bulb on passenger side is removed, they go out, but drivers side works normally, both low and high beam.
Is there a ground problem, or maybe a pinched wire between my battery and the back wall of grill, or is it maybe a modulator that got jarred and not working, where ever that would be. cant seem to figure out why light only comes on dimly, and it is involving the highbeam lights too, only dimly.
any suggestions or help???
Thanks
Nate
Old Nov 16, 2007 | 12:26 AM
Chevy Lover's Avatar
Default RE: Headlight wiring problem
It sounds like you have a poor ground.You can just splice in a new ground wire to the socket you installed. That should fix it for you.
Old Nov 16, 2007 | 11:33 AM
thats what i was thinkning but, funny enough, i jumped the wire to the battery negative and it still didnt fix it, so really weird that the gound wouldnt change anything. just wondering if the wires are crimped inside somewhere or cut behind the metal i cant see
Old Nov 16, 2007 | 11:36 AM
can you or anyone tell me, if its the wires behind the metal that i cant get to, can i spice the wires into the other headlight and just run them behind the grill and avoid the whole wiring that is there, or would that put too big of a load on one side and cause more problems or hurt the other side lights????
Old Nov 17, 2007 | 10:20 AM
drperry's Avatar
I don't think you can just ground out the lights on these things...
There's kind of a screwy voltage thing going on (the reason why it's so annoying to get the quadbeam mod to work, lol)
Make sure the fuses aren't burnt... That'll make 'em light up funny.
Not sure if the funny voltage thing applies to the '96 - '97 year, but I'm pretty sure it does for '98+
speedhead
Mar 16, 2012 06:54 PM
jayj99jimmy
Jan 11, 2012 06:33 AM
86FIFI
Sep 26, 2011 09:12 PM
nineteensixtycaddy
Sep 12, 2010 08:54 PM
Sunshine Coaster
Feb 9, 2008 02:26 PM
