HeadLights not working properly
Old Feb 10, 2009 | 06:00 PM
my96willkillu's Avatar
my96willkillu is an unknown quantity at this point
Default HeadLights not working properly
Hello to all, I've got a problem with my 96 Blazer maybe someone can help.
My Headlights are pretty much bugging out. The Day time running lights work perfectly altough u can see some flickering just a little but thats not really my concernas of now. However, My Low beams arent working at all, whenI push the switch my DT Lights turn off as if the low beams were turning on but they dont. My High Beams work But some howthe one ondrivers side blew out im guessing at the same time my Low beams went out because i have never noticedone light out.
Anyone ever have this problem??? Is it the switch??? Ive noticed that the switch was pretty much broken since I purchased the truck. You would have to press the switch down to a certain point for the headlights to turn on. If u pressed it all the way down the Headlights wouldnt go on.
Any help???
Old Feb 10, 2009 | 07:16 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
Default RE: HeadLights not working properly
Yes it does sound like the switch is going bad. It was a fairly common issue. See if you can find a used one in a junkyard because I believe it's a fairly expensive part new.
Old Feb 12, 2009 | 07:31 AM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Headlight switch at Autozone for a 96 Blazer is 17.99 plus tax. Its a cheap fix. Its also very possible the high/low dimmer switch is going bad. On my 94 Sonoma it was bad and sometimes my headlights would only work when they felt like it.
Now the dimmer switch is a different story. $232 at Autozone with cruise and tilt wheel, as the switch and handle is all one assembly.
OUCH!!!!
So it's maybe time for a salvage yard run.
austrochevy
Mar 18, 2014 01:02 PM
6gear
24
Mar 18, 2010 11:32 PM
JODYM
Jan 23, 2009 05:06 PM
JODYM
Jan 21, 2009 09:50 PM
DevizesChris
Oct 15, 2007 02:54 PM
