ABS Brakes Not Working Properly
Old Mar 15, 2014 | 04:34 AM
austrochevy's Avatar
austrochevy is on a distinguished road
Question ABS Brakes Not Working Properly
The ABS on my Blazer 4WD 1998 works not properly in low speed. The brake pedal hits back and sometimes the ABS control lamp lights up. I've already changed the ABS speed sensor on both front sides but nothing happened.
Thank you very much for your support.
Old Mar 15, 2014 | 08:14 AM
You can try this: http://ww2.justanswer.com/uploads/GM...s_bulletin.pdf
If that doesn't take care of it, you will need to get the diagnostic trouble codes retrieved, (requires a scan tool capable of accessing ABS). Post them here and we can help.
Old Mar 16, 2014 | 02:56 PM
DaveHearne's Avatar
DaveHearne is on a distinguished road
An easy thing to check is for play in your front hub bearings. Jack up the front end & grasp each wheel at the top & bottom & try to rock it back & forth. If you have play then that will upset the gap between the ABS sensor & the toothed pulse ring within the hub. This is exactly what happened to mine & it made the ABS act up in just the same way you are experiencing. In my case the drivers side hub was bad, a new assembly cured the problem - even better was the new hub came with a new ABS sensor so before I disposed of the old hub I took out the sensor to keep as a spare. I haven't yet needed it but you never know?
Old Mar 18, 2014 | 03:51 AM
kajida's Avatar
kajida is on a distinguished road
Ok so I had some serious ABS issue. I tried replacing hubs, ABS sensors, shimming the sensors, nothing worked...
What I ended up doing was removing the ABS control module, popping it open, and checking all the solder joints on it. Atleast half of the solder joints on the circuit board were cracked, which ends up giving bogus signals, which caused my ABS to act all stupid.
I resoldered all the connections on the circuit board, resealed the ABS box shut, reinstalled it, and haven't had a problem with my ABS since...
Here's the video I watched (I know its for a Jeep, but it's all the same concept.)
You have to be stupid careful. It took me about an hour to take it out, open it, fix it, and reinstall it. TOTALLY worth it, my ABS works perfect now.
Old Mar 18, 2014 | 07:12 AM
LannyL81's Avatar
Where is the ABD control module at?
Old Mar 18, 2014 | 01:02 PM
kajida's Avatar
On my 2001 Blazer LS, it's under the hood on the drivers side.
218persuader
Aug 20, 2010 06:11 PM
6gear
24
Mar 18, 2010 11:32 PM
JODYM
Jan 23, 2009 05:06 PM
JODYM
Jan 21, 2009 09:50 PM
DevizesChris
Oct 15, 2007 02:54 PM
