Heat not going to floor or defrost.
Old Oct 27, 2008 | 04:28 PM
ZQ8 Blazer's Avatar
ZQ8 Blazer is an unknown quantity at this point
Default Heat not going to floor or defrost.
Ok I'm having a problem with my 98 Blazer. This summer I did the mod to keep the heat from coming out at the floor and frying my feet. The other day I unplugged the vacuum line and plugged it back into the place it goes. Now the heat or a/c won't go to the floor or defrost vent. It will swap between hot and cold almost instantly though. What could be causing this?
Old Oct 27, 2008 | 08:33 PM
Default RE: Heat not going to floor or defrost.
No idea what "mod" it was that you did... Are you sure that everything is plugged in properly? Do you have auto temperature control?
Old Oct 27, 2008 | 09:04 PM
ZQ8 Blazer's Avatar
No I have analog controls.
The mod is unplugging the grey hose behind the glove box and plugging the clear elbow. That's the only thing to the mod and yes it's plugged in correctly. I'm going to replace my vacuum hose under the hood tomorrow.
3D_Illustrator
Aug 27, 2012 08:35 PM
reed2003
Jun 16, 2011 07:15 PM
starcruiser
Oct 17, 2009 10:52 AM
65longroof
14
May 2, 2009 04:58 PM
dunontme
Sep 22, 2008 09:49 AM
