Heat NOT working!
Old Feb 6, 2007 | 12:01 AM
ReLeNtLeSs's Avatar
ReLeNtLeSs is an unknown quantity at this point
Default Heat NOT working!
Hey,I have a 97 s10 blazer. 4.3 liter v-6, n 4 wheel drive.I have only one problem with my truck, theres no heat! There is a brand new alternator, radiator, thermostat, radiator capand water pump in it.I completely flushed the system to try and see if debri was clogging the lines and nothing. It does seem that the system is airbound tho. Is there any way to bleed the system?, or is it something else? Recently i discovered a leak of coolant inside the cab, could this have something to do with it? Its way to cold out to not have heat so ANY help is appreciated.
Old Feb 6, 2007 | 12:56 AM
20Blazer00's Avatar
Default RE: Heat NOT working!
If the coolant was on the pass side floor then your heater core is leaking coolant and won't allow it to heat to the levels you are hoping for.....to replace it will require removing the dash.
I was out in a junk yard today looking for a part for my blazer and saw the heater core in its installed location with the dash off and it is not an easy job....you will have to remove the bolts holding the upper dash to the body and that is not easy.....so good luck....
Old Feb 6, 2007 | 03:07 AM
Chevy Lover's Avatar
If you do a search, I believe that lastcoupe wrote an excellent post on heater core replacement.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
dclevette
Mar 17, 2011 11:35 PM
bootlegger
Dec 14, 2010 05:18 PM
bigdaddykane93
21
Aug 25, 2010 11:10 AM
