Heat only hot while driving
Old Jan 12, 2009 | 07:28 PM
PiTRiFF's Avatar
PiTRiFF is an unknown quantity at this point
Default Heat only hot while driving
My 1998 Blazer is doing something strange. While I am driving the heat is perfect but If Im idling in my driveway or parking lot the heat gets cold. I have plenty of antifreeze so Im stumped.
Old Jan 12, 2009 | 08:27 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
Default RE: Heat only hot while driving
have any of your cooling system replaced/flushed lately? if so it's possible you have air in the system put front right tire on a ramp and let it idle to cycle a few times to bleed the air out.
Old Jan 13, 2009 | 09:47 AM
PiTRiFF's Avatar
Are you pulling my leg? I told my mechanic buddy what you mentioned to do and he laughed at me.
Old Jan 13, 2009 | 10:01 AM
rriddle3's Avatar
So what does your mechanic buddy say the problem is?
Old Jan 13, 2009 | 10:23 AM
Outsydr's Avatar
If your mechanic buddy hasn't heard of that process for getting air out of a closed cooling system id be very leery of trusting him to work on my vehicle it's a very basic fundamental of newer vehicles (my daughter learned it in 10th grade auto shop class)
Old Jan 13, 2009 | 12:53 PM
The confusion could come from the words you used Outsydr. "Have you had your cooling system replaced/flushed" seems to ask if the entire cooling system has been replaced. I am sure you meant have you replaced the coolant and flushed the cooling system.
As far as the problem, I too would recommend a flush of the heater core. While you are driving down the road, the engine RPM is higher. This can allow for more heat capacity flowing through the core and if restricted can cause a lapse in heat output while idling.
Old Jan 13, 2009 | 01:40 PM
Outsydr's Avatar
ORIGINAL: Outsydr
What I meant was has any part of the system (ie: water pump, thermostat, radiator etc.) been replaced or flushed lately, so if my wording was confusing then my bad, I apologize for the misunderstanding.
Old Jan 14, 2009 | 08:40 PM
PiTRiFF's Avatar
I did not mean to insult you. I tried what you said and it seems better. Please accept my sincere apology.
Old Jan 14, 2009 | 08:45 PM
mrafindley's Avatar
mrafindley is an unknown quantity at this point
Some times you have to do it a cpl times and be sure the radiator cap is off. You also could have a bad radiator cap that will not hold pressure at an idle you can have it checked at any parts house
stevenhousden
Jul 6, 2014 05:56 PM
chriscrm
Jan 4, 2013 01:19 PM
Mandrwj
Apr 10, 2011 07:32 PM
88_s10
Jan 15, 2011 05:04 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
