Heat stays on. Noise from glove box area.
Old Apr 7, 2010 | 03:12 AM
Familycomesfirst's Avatar
Familycomesfirst is on a distinguished road
Default Heat stays on. Noise from glove box area.
2000 Chevy S-10 Blazer - It started in the winter, the heat was not as hot as I was used to. I also noticed that every time that I started to accelerate I heard noise that sounds like a squeaking sound from the glove box area. Now that it is getting warmer outside and I don't need the heat on and want to use the air condition or the vent air it does not work. I continue to get constant heat no matter what option that I have the control **** turned to. I have a control **** that has the auto function, dash or vents. All options have heat coming out of each. I tried to research what the problem could be. Would anyone know what the problem is? Could it be the actuator?
Old Apr 7, 2010 | 05:42 PM
crasy's Avatar
crasy is on a distinguished road
sounds like the actuator to me. i had a similar problem, and after i fiddled with the actuator for a bit the problem was fixed.
do you know how to check the actuator?
Old Apr 7, 2010 | 07:14 PM
rriddle3's Avatar
*Moved to '2nd Gen Tech'*
Old Apr 8, 2010 | 11:08 PM
Thank you for the advise. I have been unable to fiqure out how to fiqure out how to get to the actuator, and I don't now how to check it.
luvmymoneypit
13
Apr 24, 2013 08:31 AM
dj00140
Dec 14, 2011 01:58 AM
p72lwor
16
May 12, 2008 11:43 AM
Zygoat
Apr 3, 2007 01:54 AM
2FAST4U
Aug 12, 2005 02:30 PM
